Hi Brad,
No KMotionCNC only supports doing it with GCode. But you should be able to just set the Interpreter's parameters directly see below:
pars = settings->parameters;
k = (5200 + (_setup.origin_index * 20));
SET_ORIGIN_OFFSETS((pars[k + 1] + pars[5211]),
(pars[k + 2] + pars[5212]), (pars[k + 3] + pars[5213]),
(pars[k + 4] + pars[5214]), (pars[k + 5] + pars[5215]),
(pars[k + 6] + pars[5216]));
Message: 2418 |
Date: 11/25/2011 |
Subject: Re: Origin Offsets.... cripes |
Hello Tom, I started implementing this last night and I have it working, but I am unclear how your array indexing scheme relates to the addresses used by 54-59.x…. Is there a doc that describes this relationship? Can you spell things out if not? Sorry for the hassle. -Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes Sent: Friday, November 18, 2011 7:08 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] Origin Offsets.... cripes No KMotionCNC only supports doing it with GCode. But you should be able to just set the Interpreter's parameters directly see below: pars = settings->parameters; k = (5200 + (_setup.origin_index * 20)); SET_ORIGIN_OFFSETS((pars[k + 1] + pars[5211]), (pars[k + 2] + pars[5212]), (pars[k + 3] + pars[5213]), (pars[k + 4] + pars[5214]), (pars[k + 5] + pars[5215]), (pars[k + 6] + pars[5216])); From: bradodarb <bradodarb@...> To: DynoMotion@yahoogroups.com Sent: Friday, November 18, 2011 4:35 PM Subject: [DynoMotion] Origin Offsets.... cripes Hello Tom,
One thing I forgot about implementing was orgin offset definitions....
I do not see where you do that in KMCNC, but I did see it in an example gcode program.
Do you have a method for populating these offset structures from code?
Thank you,
Brad Murry
Message: 2421 |
Date: 11/25/2011 |
Hi Brad,
That isn't really "my" scheme but rather from the original EMC code and specification. I'd have to research/reverse engineer it.
But it seems like the origin offsets are just indexed by 20 variables (even though only 6 are needed). See the origin_index*20 below.
Google found this:
coordinate parameters emc.var Parameter Number(s) Meaning
5061-5069 Result of “G38.2” Probe
5161-5169 “G28” Home
5181-5189 “G30” Home
5211-5219 “G92” offset
5220 Coordinate System Number
5221-5229 Coordinate System 1
5241-5249 Coordinate System 2
5261-5269 Coordinate System 3
5281-5289 Coordinate System 4
5301-5309 Coordinate System 5
5321-5329 Coordinate System 6
5341-5349 Coordinate System 7
5361-5369 Coordinate System 8
5381-5389 Coordinate System 9
5399 Result of M66 - Check or wait for input
Message: 2424 |
Date: 11/25/2011 |
I could just shoe-horn this into the interop, but wondered if this might be useful to others. Should I implement this in GCodeInterpreter first so it is available for KMotionCNC? -Brad Murry From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes Sent: Friday, November 25, 2011 12:25 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] Origin Offsets.... cripes That isn't really "my" scheme but rather from the original EMC code and specification. I'd have to research/reverse engineer it. But it seems like the origin offsets are just indexed by 20 variables (even though only 6 are needed). See the origin_index*20 below. coordinate parameters emc.var Parameter Number(s) Meaning 5061-5069 Result of “G38.2” Probe 5161-5169 “G28” Home 5181-5189 “G30” Home 5211-5219 “G92” offset 5220 Coordinate System Number 5221-5229 Coordinate System 1 5241-5249 Coordinate System 2 5261-5269 Coordinate System 3 5281-5289 Coordinate System 4 5301-5309 Coordinate System 5 5321-5329 Coordinate System 6 5341-5349 Coordinate System 7 5361-5369 Coordinate System 8 5381-5389 Coordinate System 9 5399 Result of M66 - Check or wait for input I started implementing this last night and I have it working, but I am unclear how your array indexing scheme relates to the addresses used by 54-59.x…. Is there a doc that describes this relationship? Can you spell things out if not? No KMotionCNC only supports doing it with GCode. But you should be able to just set the Interpreter's parameters directly see below: pars = settings->parameters; k = (5200 + (_setup.origin_index * 20)); SET_ORIGIN_OFFSETS((pars[k + 1] + pars[5211]), (pars[k + 2] + pars[5212]), (pars[k + 3] + pars[5213]), (pars[k + 4] + pars[5214]), (pars[k + 5] + pars[5215]), (pars[k + 6] + pars[5216])); Hello Tom,
Thank you,
Brad Murry
Message: 2425 |
Date: 11/25/2011 |
Hi Brad,
Not sure what you mean. Like add special functions to avoid the magic numbers?
Message: 2426 |
Date: 11/25/2011 |
Exactly... Magic bad much
-Brad Murry
Sent:
11/25/2011 1:11 PM
To:
Subject:
Hi Brad,
Sent: Friday, November 25, 2011 11:52 AM
Subject: RE: [DynoMotion] Origin Offsets.... cripes
-Brad Murry
5301-5309
Coordinate System 5
5399
Hello Tom,
Thank you,
Brad Murry
Message: 2428 |
Date: 11/25/2011 |
Ok sure. Make changes relative to the V4.28x version and we will merge them in.
